Rs cosworth L1 ecu injector choice
Old Mar 10, 2024 | 11:27 AM
Timo_iepsma's Avatar
Timo_iepsma
Default Rs cosworth L1 ecu injector choice
Hello,
got a question about what injectors u can run on a L1 ecu. I am running green 803’s but planning on te get arround 350 bhp with en gtx2860rs. I know that i could run 403 but those are hard to get and big expensive. So are there other options now a days?
greetz timo
Netherlands
Old Apr 13, 2024 | 12:03 PM
cossynut2's Avatar
cossynut2
10 Year Member
Hi, you will always be limited what injectors you can run with an L1 ecu, if you can afford the cost ,swap to either an L8 ecu from a 4x4 Sapphire or an aftermarket modern ecu which will give you lots of choices for high impedence injectors.Old school injectors are low impedence but big injectors like I run in my 2wd Sapphire ,Siemens 890cc are hard to find these days and are expensive plus you need an extra baby board driver. Cheers Richard.
studabear
Sep 28, 2010 06:27 PM
ybturbo
17
Jun 16, 2009 12:26 PM
white cab
Dec 10, 2006 06:07 PM
Alg1k
Nov 29, 2003 05:10 PM
