1.8 silvertop zetec wiring help
Old Feb 21, 2024 | 04:32 PM
RIB1122's Avatar
RIB1122
Default 1.8 silvertop zetec wiring help
I’m installing a 1.8 silvertop zetec and need some help with the engine/ecu loom
anyone know who’s best to speak to?
basically I need to know where the following wires go on the loom
12v battery feed
ign feed
earth
fuel pump feed
Old Feb 21, 2024 | 05:14 PM
BIG LEE's Avatar
BIG LEE
12v battery feed
ign feed
earth
fuel pump feed
what you wanting to fit it into? are you just trying to use a cut down loom
Old Feb 21, 2024 | 05:50 PM
RIB1122's Avatar
RIB1122
It’s going into a kit car
ive got a cut down loom just want to know what goes where!
Old Feb 21, 2024 | 06:06 PM
BIG LEE's Avatar
BIG LEE
Are you just going to run the std injection etc? most people i know who have done these use a mk1 focus ecu loom or the older cvh efi stuff with edis..
Old Feb 21, 2024 | 06:07 PM
RIB1122's Avatar
RIB1122
It’s a pre pats ecu with edis
running efi system
andyxr2zetec
Jul 20, 2011 01:07 PM
scoobypete
Feb 23, 2011 06:15 PM
