Ford KA Discuss your Ford KA here!
Error codes
Old Jan 16, 2024 | 08:33 PM
Jinkie's Avatar
Jinkie
Default Error codes
I have a 2009 ka that is not starting I have ran the codes and these are the errors that are coming up
U1705 receiver radio (NRR)
No node on B-CAN
Error counter 40
U1701 ENGINE CONTROL module can transmission
No node on C-CAN
U0426 MINICRYPT
Error counter 40
Has anyone had these codes and managed to sort them any help in what the mean thanks
Old Jan 16, 2024 | 09:36 PM
GVK.'s Avatar
GVK.
Guessing this is the Fiat type Ka? I had one once (fiat 500) that wouldn't start and it was the ECU not firing the injectors. Was a brand new car!
Fiat field tech came out and verfied the fault by checking the earth pulse with a test light onto the injectors. New ECU required.
Old Jan 16, 2024 | 09:59 PM
Jinkie's Avatar
Jinkie
Yeh it is the Fiat engine is do you know if it’s just a case of replacing the ecu or getting a kit from a dooner car thanks
Old Jan 16, 2024 | 10:04 PM
GVK.'s Avatar
GVK.
As it was a brand new car we fitted a vigin ECU and it was initialised with the Fiat diagnostics.
I say we, I just watched the Fiat guy
Luchyloo
Jun 17, 2021 07:12 PM
stephen.carroll88
May 3, 2010 07:54 AM
dvid
Jan 29, 2009 09:48 AM
COMEDY DAN
37
May 14, 2006 05:47 PM
