Tyre pressure warnings
Old Jan 8, 2024 | 07:52 AM
rondetto's Avatar
rondetto
10 Year Member
Default Tyre pressure warnings
Today a warning came up that all four tyre pressures were low. So I have pumped them up to the required level but it's still showing the warning. I pressed OK on the steering column but makes no difference.
How do I get rid of these warnings?
Thanks for any replies.
Old Jan 8, 2024 | 10:33 AM
STeve's Avatar
Super Moderator
could be a battery going flat in one of the tyre sensors, some cars actually tell you the problem with what wheel others simply say as yours does, if you have done the tyre reset in your menu or confirmed tyre pressure is ok its likely to be a battery
Old Jan 8, 2024 | 10:51 AM
rondetto's Avatar
rondetto
10 Year Member
Thanks Steve.
Old Jan 9, 2024 | 10:45 AM
rondetto's Avatar
rondetto
10 Year Member
Thanks Steve, I can't find anything to do with tyres in the menu settings. I found factory reset and clicked that but it still says tyre below level. Any ideas where the tyre monitor might be please?
Old Jan 9, 2024 | 06:57 PM
GVK.'s Avatar
GVK.
Have you got an owners manual?
Old Jan 10, 2024 | 12:55 PM
STeve's Avatar
Super Moderator
Very unusual really depends on models and brand of car etc , as my mk3 focus gives you tyre settings etc in information sub menu, as mentioned should be coverd in your cars handbook or if its newer car and a ford may find owners manual free online to access as newer fords are
Old Jan 10, 2024 | 01:04 PM
rondetto's Avatar
rondetto
10 Year Member
I have looked at the manual Steve, but can't find anywhere on my car in settings that gives you Tyre monitor. I rang the local Ford dealer and he said I have to take it in for them to reset.
Old Jan 13, 2024 | 01:35 PM
rondetto's Avatar
rondetto
10 Year Member
Been to the dealer today and he's sorted it out now. There's no menu on my 2023 Eco sport but he found it on the steering column. Pressed reset to new pressures and away to go.
cutch
Jan 27, 2011 08:05 PM
THE RADMAN
Ford Escort RS Cosworth
Jul 10, 2007 09:43 PM
zetec-phil
Fiesta RS1800/RS Turbo
May 16, 2007 03:11 PM
7.77
Feb 11, 2006 08:25 AM
