Focus at MK2 oil leak help
Old Oct 22, 2023 | 05:04 PM
Lee read's Avatar
Lee read
Rs turbo
Default Focus at MK2 oil leak help
hi guys after a little help. So it's a fully rebuilt engine and it's done about 500/600 running in miles no boost. So I've noticed it's been leaking oil so I gave it a good degreas and clean today. Started her up to see if I could spot where it's coming from and the only place I can see oil is around the water pump!! Any help as to where it may be coming from so welcome. Or the engine will be out and all gaskets and seals done again. Thanks
Old Oct 23, 2023 | 10:05 PM
studabear's Avatar
studabear
is it tracking down from a cam sealor head gasket?
Old Oct 23, 2023 | 10:08 PM
Lee read's Avatar
Lee read
Rs turbo
Not quite sure mate. From being on the water pump I'm guessing it's coming from the rear cam seal. Head gasket looks to be ok from what I can see
Old Oct 24, 2023 | 07:06 PM
GVK.'s Avatar
GVK.
Oh, you must have had it running, what was stoppping it from starting?
Agree rear cam seal btw
Old Oct 24, 2023 | 07:26 PM
Lee read's Avatar
Lee read
Rs turbo
It still runs perfect just the oil leak. Had a quick look doesn't seem to be rear cam seal but did spot something that's bothering me slightly so buying an inspection camera to look better
Old Oct 24, 2023 | 07:30 PM
Lee read's Avatar
Lee read
Rs turbo
So that's the top of the water pump and it's dry
Old Oct 27, 2023 | 05:17 AM
haz87's Avatar
haz87
The hell is causing that HG gap?
Old Oct 27, 2023 | 11:53 AM
Lee read's Avatar
Lee read
Rs turbo
I don't know mate. I cleaned it all up and found a pipe that was loose on top of the turbo biut still leaking. I think I'm going to whip the turbo off and give that an inspection
Old Oct 27, 2023 | 12:04 PM
Lee read's Avatar
Lee read
Rs turbo
Old Oct 27, 2023 | 12:05 PM
Lee read's Avatar
Lee read
Rs turbo
I also think it leaks when it's under load. Doesn't really leak idling
Old Nov 5, 2023 | 02:30 PM
Lee read's Avatar
Lee read
Rs turbo
Hi guys I'm suspecting a head gasket as I've seen this let me know what you think. That's at the back just above the turbo
we
Old Nov 6, 2023 | 06:40 AM
haz87's Avatar
haz87
Thats what I meant when I said "The hell is causing that HG gap?" (HG - Head Gasket)
Your mating surfaces should be completely flush, sandwiching the head gasket. This is going to be causing issues
Old Nov 6, 2023 | 08:44 AM
Lee read's Avatar
Lee read
Rs turbo
Ye I I noticed the other bit yesterday. Il be taking the head off and checking everything. And obvs replace
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
cookie1983
Jun 23, 2015 07:35 AM
pocket_rocket
Fiesta RS1800/RS Turbo
Aug 18, 2008 12:25 PM
sjm
Sep 10, 2006 09:48 AM
turbodan
Jun 13, 2006 09:59 AM
