Ford focus mk2 2010 nsf headlight not working
Old Sep 2, 2023 | 03:53 PM
Default Ford focus mk2 2010 nsf headlight not working
Right people bit of a strange one here.
The Mrs and I own a mk2 1.6 16v petrol focus on a 2010.
The nsf headlight bulb won't work. I've replaced the bulb,check the fuses.
I've plugged the nsf headlight into the osf and the head light works. Ive found the live feed to the headlight. As soon as i plug the headlight back in the live feed/wire turns to a earth??
I'm thinking is the body computer at fault.??
Old Sep 10, 2023 | 11:26 AM
I got the headlight working but I had to take a feed off the osf headlight and used it as a trigger wire for a relay which I put in to power the headlight.
Old Sep 11, 2023 | 07:53 PM
stevieturbo's Avatar
stevieturbo
C**t
likely a broken wire somewhere
Old Sep 12, 2023 | 06:51 PM
Yeh im thinking that now. I might have a proper look sometime when I've got a spare few hours.
capri-rs
Mar 14, 2016 01:30 PM
chrisg69
Ford Focus (All Models)
Sep 9, 2011 05:56 PM
dj0nes
Mar 25, 2010 12:55 PM
