No brakes on sapphire 4x4
Old Jul 15, 2023 | 08:20 PM
trentt's Avatar
trentt
donkey
Default No brakes on sapphire 4x4
4x4 saph, just tried bleed the brakes back up, cant get a firm peddle.
i ran silicone fluid before, Had all the calipers re sealed, any chance ive fucked up the master cylinder ?
All bled correctly.
Old Jul 15, 2023 | 08:54 PM
james kiely's Avatar
james kiely
was the master cylinder dry?
Old Jul 16, 2023 | 08:34 AM
trentt's Avatar
trentt
donkey
not sure, possibly as all the brake lines have been off, but everthing in the engine bay stayed on.
Old Jul 16, 2023 | 11:17 AM
james kiely
sometimes it can take a while to get air out of the master cylinder
Old Jul 17, 2023 | 10:08 AM
Marc sierra's Avatar
Marc sierra
This weekend my sapph 4x4 actually developed a problem with the ABS valve block. In your case it could also be caused by that. Some valves in the valve block can actually direct the fluid back to the reservoir, so if those valves are open (which they normally shouldn't be) you will not get fluid pressure at the calipers.
Do your brakes actually work, but it is the pedal spongy? In that case I think there will still be air in the system.
Old Jul 17, 2023 | 10:19 AM
trentt's Avatar
trentt
donkey
yeah i can get brakes but pedal goes down, i can get half a pedal if that makes sence, i was told silicone fluid knackers the seals,
munchgsy
Apr 22, 2012 09:54 PM
J9BBY
Aug 24, 2007 02:11 PM
RS16iDale
Apr 9, 2007 01:03 PM
