Cosworth coolant hose diagram
Old Jun 7, 2023 | 08:06 PM
Robzilla's Avatar
Robzilla
Default Cosworth coolant hose diagram
Hello, I am looking for some help , I am looking for a coolant hose diagram as I’m trying to rebuild a Sierra with a cossie engine in and don’t have all the parts, also I didn’t take it apart , any help would be appreciated, thank you
Old Jun 7, 2023 | 08:20 PM
qed296's Avatar
qed296
4x4 diagram
Old Jun 7, 2023 | 09:08 PM
Robzilla's Avatar
Robzilla
Thank you, I did find that diagram, there’s a metal pipe that seems to run along the bottom of the radiator, is that for a cosworth?
Old Jun 7, 2023 | 09:47 PM
qed296's Avatar
qed296
Yes, 2 different types though...2wd is a straight pipe with 2 mounting points and the 4x4 type with 3 mounts and a 90⁰ bend in.
Old Jun 9, 2023 | 05:31 AM
Robzilla's Avatar
Robzilla
Is this pipe in the diagram above
Old Jun 9, 2023 | 05:45 AM
qed296's Avatar
qed296
Shown in red - it sits level/below the bottom of the radiator.
Old Jun 9, 2023 | 06:30 AM
Robzilla's Avatar
Robzilla
Brilliant thank you
Old Jun 9, 2023 | 09:39 AM
qed296's Avatar
qed296
No worries.
Old Jul 28, 2023 | 12:15 AM
charlie luciano's Avatar
charlie luciano
early 4x4 sapphires also had a straight pipe, my one was a 90 4x4 and pipe was straight, the later sapphires had subtle differences with pipe work, such as the power steering, early 4x4’s had the ‘piggy tail’ pipe whereas later sapphires had iirc a part metal/part hose pipe which was quite long, pipe was the same part for escort Cosworths
Old Jul 31, 2023 | 02:59 PM
Robzilla's Avatar
Robzilla
Default Coolant hose
I’m still trying to get my head around the coolant hose routing, I have 2 ports coming off thermostat housing, is this the wrong housing? Does one go to the turbo? Which one goes back to the header tank? Thanks
Old Jul 31, 2023 | 03:04 PM
qed296's Avatar
qed296
Guessing its a 2wd set up?
Old Jul 31, 2023 | 05:29 PM
Robzilla's Avatar
Robzilla
Yes 2wd, oil feed for turbo as well
studabear
12
Apr 14, 2013 11:56 AM
SandertjuhXR4I
Jun 9, 2012 09:17 AM
groomers
Apr 20, 2010 10:46 AM
pani_k
Dec 9, 2008 03:15 PM
