Zetec crankshaft gear
Old Jun 5, 2023 | 08:34 PM
Togneri's Avatar
Togneri
Default Zetec crankshaft gear
Hi everyone,
I have a kitcar with a 2.0 zetec (silvertop code NGA). I’ve had the crank oil seal fail, emptying the car of oil on my in-laws drive…
The ‘slide on’ crankshaft gear/washer (pictured below) was really stuck on, no levering could free it, so eventually I drilled and tapped a couple holes into the gear to fashion a pusher. So the gear now has two holes in it. The washer is also looking pretty knackered.
I can’t find any of these for sale, which means I think it’s going to be a case of going to scrapyards to find a replacement. My question is - does anyone know if this part is the same across all zetec engines? Mine has 20 teeth and is 59mm in diameter.
Tank Mike
Ford Focus Range
Jul 29, 2016 03:54 PM
luxembourgrst
Jun 16, 2013 01:43 PM
markk
Dec 11, 2010 06:37 PM
kamkam
Ford Focus RS
Aug 12, 2009 10:38 PM
