Fiesta MK4/MK5 door hinge pin stuck
Old May 26, 2023 | 04:00 PM
Jesse's Avatar
Jesse
Angry Fiesta MK4/MK5 door hinge pin stuck
Hi guys, i have problem with getting the hinge pins out of the hinges, they are really stuck! I used a blow torch, WD40 and a screwdriver with hammer. I got some movement in the upper pin and now it doesn't move any more, still haven't tried the bottom one. They need to be replaced because the door is sagging a lot.
Old May 26, 2023 | 08:42 PM
BIG LEE's Avatar
BIG LEE
plenty of deep breaths and keep at it... had one in mk1 escort hinge same lucky i was restoren car but ended up just usen loads nd loads of heat and light oil soakn it over time it come out in the end but burnt all paint off etc due to heat... there can be very hard to remove tho and im not sure of a simple fix sadly
Old May 26, 2023 | 08:47 PM
Jesse's Avatar
Jesse
Thanks! I will order some paint than
Old May 26, 2023 | 08:56 PM
GVK.'s Avatar
GVK.
Get some punches instead of hitting a screwdriver
Old May 27, 2023 | 02:35 PM
stevieturbo's Avatar
stevieturbo
C**t
there used to be proper tools for this.
https://www.sealey.co.uk/product/563...e-pin-tool-set
Amazon Amazon
Or you could try and make something yourself ? This isn't it, but you get the idea.
https://www.ebay.co.uk/itm/310693387290
https://cwmoss.com/products/door-hinge-pin-removal-tool-kit-1932-48
Old May 27, 2023 | 07:56 PM
Jesse's Avatar
Jesse
Thanks for the recommendations! I will buy some punches. The fiesta goes to the garage 5 june for the yearly examination, maybe the garage hase a special toof for these suckers.
ArronP
Feb 8, 2014 06:07 PM
baxter
Ford Fiesta
Jan 7, 2013 07:06 AM
DrewSS
Jun 16, 2010 03:10 PM
sheeks
Apr 17, 2010 03:49 PM
