yb short rods with long pistons
Old May 23, 2023 | 08:24 PM
lime's Avatar
lime
Default yb short rods with long pistons
what would be the down side of using long pistons with the std short connecting rods on a yb 200 block
Old May 27, 2023 | 02:31 PM
stevieturbo's Avatar
stevieturbo
C**t
What do you mean by "long pistons" ??
Old May 27, 2023 | 02:34 PM
lime's Avatar
lime
I have attached a link to the piston in question , but I should have said long rod piston.
https://modatek.co.uk/product/yb-lon...v=9d3d9048db16
Old May 27, 2023 | 02:38 PM
stevieturbo
C**t
Obviously if you used that piston with standard rods and standard stroke crank, the piston will sit down the bore by 7.5mm at TDC, giving you an utterly ridiculously low compression.
It would be a very very very silly thing to do.
Old May 27, 2023 | 02:42 PM
lime's Avatar
lime
Ok the reason for the question was I am currently in a rebuild of my yb , I bought some pistons off a guy but when researching the part numbers I was not able to find much information on them. So wanted to know what would happen if I were to use that combination. But since I have measured against the old piston and there are not much difference between them
Old May 27, 2023 | 02:51 PM
stevieturbo
C**t
Except if it is those pistons, there is a massive 7.5mm difference in compression height. That is a huge difference.
So are the compression height of both your pistons the same ?
Old May 27, 2023 | 02:54 PM
lime's Avatar
lime
Yes both the same height.
Old May 27, 2023 | 02:59 PM
stevieturbo
C**t
Then for the most part, yes they should be fine to use. The new pistons will need piston rings to suit etc.
They are clearly not the piston designed for the long rod setup.
Old May 27, 2023 | 03:00 PM
lime's Avatar
lime
They came with everything needed to install
Old May 27, 2023 | 03:11 PM
stevieturbo
C**t
Should be all good then.
Old May 27, 2023 | 03:17 PM
lime's Avatar
lime
Thanks for the response
crazydan
Mar 16, 2013 07:31 PM
DixieTheKid
Jan 12, 2012 11:55 AM
pacwest
Sep 17, 2009 05:15 PM
MalteseFalcon
Mar 27, 2007 04:45 PM
cossied
Jun 10, 2004 12:02 PM
