Cosworth 4 or 36 teeth timing pulley
Old May 22, 2023 | 02:14 PM
s9ott's Avatar
s9ott
s9ott
Default Cosworth 4 or 36 teeth timing pulley
Got a YB Cosworth with a L8 ECU running a 4 tooth timing pulley, what do you need to do to change it to a 36 tooth pulley ?
Reason for the question is I'm buying new alloy pulleys, so have the option for changing it now to a 36 tooth pulley giving it a better timing setup.
Scott
Old May 22, 2023 | 05:03 PM
james kiely's Avatar
james kiely
im not sure if your l8 has the option of running a 36-1 scott.worth asking your tuner
Old May 23, 2023 | 01:53 PM
s9ott's Avatar
s9ott
s9ott
Your right the L8 can't support the 36-1 timing, just had reply from MSD who's chip I'm running in the L8 ECU
cheers
Scott
Miller 3
Nov 7, 2010 11:47 AM
saph-mad
Nov 4, 2010 08:51 PM
saph-mad
Nov 4, 2010 12:50 AM
MARKYMARKONE
Apr 7, 2008 06:14 AM
Ian M
Jun 28, 2006 06:45 AM
