Zetec turbo
Old May 13, 2023 | 03:08 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default Zetec turbo
Hi ,
We've just put a 2.1 zetec turbo into my brothers s2 rs turbo. It was running a 2.1 zvh beforehand.
Only things changed apart from 8v to 16v head is the inlet manifold.
We can start the engine but wants to rev at approx 1500/ 2000 rpm. There's no cam sensor, so I can't see what is causing the really fast idle. It's running ofam ( mega squirt ) management.
Has anyone got any ideas?
cheers mark
Old May 14, 2023 | 08:32 PM
studabear's Avatar
studabear
Big air leak?
ISCV stuck or incorrectly tuned
Throttle stuck?
What inlet are you using?
Old May 16, 2023 | 07:10 PM
MARKYMARKONE
OK so found that the air leak was caused by the breather system, now idles as it should do. Thanks for your input
MARKYMARKONE
May 18, 2023 09:13 PM
EscoVan
Nov 16, 2010 08:46 PM
Andy Tucker
12
Jan 21, 2009 11:50 AM
carls9941
May 27, 2008 06:51 AM
slimwynn
Jan 1, 2007 10:03 PM
