Zetec turbo
Old May 13, 2023 | 03:08 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default Zetec turbo
Hi ,
We've just put a 2.1 zetec turbo into my brothers s2 rs turbo. It was running a 2.1 zvh beforehand.
Only things changed apart from 8v to 16v head is the inlet manifold.
We can start the engine but wants to rev at approx 1500/ 2000 rpm. There's no cam sensor, so I can't see what is causing the really fast idle. It's running ofam ( mega squirt ) management.
Has anyone got any ideas?
cheers mark
Old May 13, 2023 | 03:32 PM
XR2's Avatar
XR2
1. Get rid of that megasquirt crap
2. Get it properly set up.
Old May 18, 2023 | 02:07 PM
stevieturbo's Avatar
stevieturbo
C**t
Originally Posted by MARKYMARKONE
Hi ,
cheers mark
So you've made a massive change, and never been tuned/set up correctly....and you wonder why it isn't running right ?
Have a think about that.
And on a most basic level, if idle is too high, then it is getting too much air or to a lesser degree perhaps too much timing.
Which goes back to the first point....everything needs set up/tuned correctly for the entirely different setup.
Old May 18, 2023 | 09:13 PM
MARKYMARKONE
We found the air leak to be caused by the breather system, so now idles as it should do.
I am fully aware the vehicle needs setting up, but whats the point in paying a tuner x amount of time to find and fix an issue we can do, before hand
Thanks for your input
Mark
MARKYMARKONE
May 16, 2023 07:10 PM
EscoVan
Nov 16, 2010 08:46 PM
Andy Tucker
12
Jan 21, 2009 11:50 AM
carls9941
May 27, 2008 06:51 AM
slimwynn
Jan 1, 2007 10:03 PM
