siemens 55lbs
Old Apr 30, 2023 | 08:02 PM
saph4be's Avatar
saph4be
Default siemens 55lbs
anyone any leads on any I'm after a set desperately!
Old May 1, 2023 | 09:12 AM
mattman1234's Avatar
mattman1234
Do they do a replacement for these ?
Old May 2, 2023 | 08:53 AM
cossynut2's Avatar
cossynut2
10 Year Member
If you after low impedence Siemens injectors they are getting harder to find but if you are running modern electrics and ECU you should be able to find some high impedence ones even if they are not Siemens which will be the equivalent.I did find the low impedence 83lb Siemens injectors I was after in Australia but not sure if they are still available.
Old May 2, 2023 | 05:51 PM
stevieturbo's Avatar
stevieturbo
C**t
And what suppliers have you contacted already ?
Have you tried ASNU to see if they can make you a set ?
Why specifically Siemens ? And as said, do you need high impedance or low impedance ?
Racetronix in the US offer a few 55lb low impedance injectors if that's the sort of thing you're stuck having to use
https://www.racetronix.biz/c/fuel-in...impedance/c376
Old May 4, 2023 | 05:46 PM
mattman1234
Theres some on facebook market place in a bundle of gear the guy is selling
Old May 4, 2023 | 05:54 PM
mattman1234
https://www.facebook.com/marketplace/item/972649817435317?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Aa81242b7-5c8a-4013-a3f1-c92d9ba669c2
Old May 5, 2023 | 06:41 PM
saph4be's Avatar
saph4be
found some cheers
Old May 6, 2023 | 07:07 AM
cossynut2's Avatar
cossynut2
10 Year Member
found some cheers
Which Siemens injectors did you find? Low impedence ? If you are using an L8 ecu have you had a baby board installed as a driver?
Cosnada
May 1, 2012 07:05 PM
LHD220Turbo
Feb 15, 2008 05:53 PM
Stu @ M Developments
225
Sep 2, 2007 09:32 AM
bozz
Mar 2, 2005 07:48 AM
