Full throttle misfire 91 Sapphire 4x4
Old Apr 25, 2023 | 07:22 PM
alexrat's Avatar
alexrat
Default Full throttle misfire 91 Sapphire 4x4
I have recently bought a Cosworth. has a misfire that comes on when going to full throttle.
- swapped plugs and wires and new rotor as well which made it a bit better but still has a problem.
- at part/slight throttle it seems fine/better but as soon as you give it more than 50% it breaks up.
- wondering where to look next. plugs where very sooty and it was difficult to start as well.
any pointers would be greatly appreciated.
Cheers.
Old Apr 25, 2023 | 07:58 PM
james kiely's Avatar
james kiely
alex ,the very best thing you can do is upgrade your management,injectors and loom on a cossie .all that old wiring and old management won't do you any favours ..
my first port of call would be the engine multiplugs on the cowl at the back of the engine .pull them apart and clean the connectors.
Old Apr 27, 2023 | 07:02 AM
Brocker's Avatar
Brocker
Is the boost maybe to high?
Are the coorect plugs mounted with correct cap?
Are all houses correct monted and tight?
Are the ignition timing correct adjusted?
Test Sensors for ACT, ECT, Phase. Do they work correct and connectors are dry?
Mark RS
Oct 12, 2014 07:32 PM
GaryHurn
Feb 4, 2011 06:57 PM
col cos1
Jun 4, 2009 06:59 PM
17-APG
Apr 8, 2008 10:48 AM
