730 hp cosworth performance figures
Old Apr 13, 2023 | 06:43 AM
scoooby slayer's Avatar
scoooby slayer
Default 730 hp cosworth performance figures
Ex rod tarry cosworth is finally home with me 😁😁
been sorting bits and pieces on it, but managed to get some timing done, at 2.4 bar which is about 730 hp
I managed 80-120 mph in 3.3 seconds 3rd gear grip all the way
And also a 100-200 kph time of 5.8 seconds, but I had to use 2nd and 3rd gear for this and 2nd gear was lots of wheelspin so gotta try new tyres and warmer tarmac to see how much that helps
Old Apr 13, 2023 | 07:35 PM
james kiely's Avatar
james kiely
supercar times those carl
Old Apr 13, 2023 | 09:28 PM
scoooby slayer
Yes mate definately manual times, production manuals Ferrari F40 7.1 seconds, McLaren F1 5.1.
I think a low 5 or high 4 on the cards perfect shift with new tyres hot tarmac 🙏🤞
Old Apr 14, 2023 | 09:28 AM
Marc sierra's Avatar
Marc sierra
I did 2.3 sec for 80-120 in 3rd gear, but that was in kph.
It's really crazy to see the times it does! How much would it take for 200-300 kph?
Old Apr 14, 2023 | 03:30 PM
Could upset alot of people with this car.
Old Apr 15, 2023 | 12:25 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Proper fast for an Old Ford top car mate
Old Apr 15, 2023 | 06:52 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
serious figures them, will keep an eye on the tests in the future.
Old Apr 21, 2023 | 09:46 PM
scoooby slayer
I would hazard a guess around 9 seconds
Old Apr 21, 2023 | 09:48 PM
scoooby slayer
Yeah Its got plenty of go mate 👍
Cheers pal 🤝
Thanks mate more to come, new tyres now fitted, couple more jobs gotta be done then try again 😁😁
Old Apr 22, 2023 | 05:47 AM
charlie luciano's Avatar
charlie luciano
I bet that proper pins you into the seat nice to hear the car is still on the circuit and performing well enjoy it
Old Apr 22, 2023 | 07:18 PM
Adam-M's Avatar
Adam-M
Car sounded nuts in Adam Smiths video
Out of interest, i seen Adam filmed an 850hp Evo 9 whilst at MAD, was the evo on the exact same 9180 turbo or was it bigger? I assume the evo was on race fuel
Old Apr 23, 2023 | 07:23 AM
scoooby slayer
It's great fun mate 😁😁👍👍
Old Apr 23, 2023 | 01:20 PM
scoooby slayer
I asked mark it's on pump with water/meth injection
Old Jul 2, 2023 | 05:58 PM
scoooby slayer
More times, full grip and traction all the way 100-200 kph 4.97 seconds, well chuffed 😁😁
Old Jul 3, 2023 | 12:51 PM
STeve's Avatar
Super Moderator
not bad for a taxi
Old Jul 14, 2023 | 10:37 PM
scoooby slayer
Originally Posted by STeve
not bad for a taxi
Most enjoyable car to drive I own mate, love it 😁😁
Old Jul 19, 2023 | 06:38 PM
Very impressive.
Old Sep 21, 2023 | 03:52 PM
NevilleMccoy's Avatar
NevilleMccoy
Old Sep 22, 2023 | 06:49 PM
james kiely
are you running traction control carl ,or how well does the diff lock up?
Old Sep 23, 2023 | 05:21 PM
scoooby slayer
Very impressive.
Cheers Glenn
It does go well just waiting for install of new block to be finished should be more reliable then going forward
It does have traction control but I've decided not to have it active, it's hard on the engine as it needs to cut alot of power to stop all wheelspin, and it's way more fun driving it on the throttle mate.
60 mph onwards In 3rd gear it clean hooks, 2nd gear it's sort of spin and go it's great fun just need headgasket to last longer 🤣😂
Diff works perfectly pic is of a quick diff test I did down my road
Old Sep 23, 2023 | 09:28 PM
james kiely
i would have thought the emtron you could dial in the amount of slip you wanted to go with like on the motec carl .at least you were able to keep the car in a straight line carl lol
Old Sep 23, 2023 | 09:46 PM
scoooby slayer
Most likely but I love it just being man and machine abs is all I need 😁😁
Old Sep 27, 2023 | 07:26 PM
james kiely
carl by any chance have you a pic of how your diff is mounted from the beam to the floor mate ?
Old Sep 27, 2023 | 08:08 PM
scoooby slayer
I could only find this one
Diff is solid mounted to the beam, it's pretty full in there no room to do anything I don't think, havnt noticed any vibrations though not from the back
Old Sep 27, 2023 | 08:10 PM
james kiely
thanks carl.i got my beam today and i see that the diff bolts to the beam .is the beam then bolted to the floor ?
Old Sep 27, 2023 | 08:44 PM
scoooby slayer
Cars at marks having engine done but I think it's solid mounted to the original mounting point, I don't think there's any room to have a rubber mount in there.
I've not noticed any vibrations from rear, feels good, only vibration issue I've had is from engine mounts and gearbox mount
Old Sep 27, 2023 | 09:21 PM
james kiely
thats great to know thanks carl .i was concerned it would vibrate badly if solid mounted .i was considering making a recess in the floor to take a mount as it does look tight
Old Sep 28, 2023 | 05:58 AM
scoooby slayer
That is a good idea mate I hadn't thought of doing it chassis side, while I don't feel any vibration from the rear I have had to tighten alot of bolts around the diff and rear beam as they had come loose, but they've stayed tight so far since I torqued them all up, I'd guess couple hundred miles so far I've done
Old Sep 28, 2023 | 10:52 AM
james kiely
when you do geta chance please carl when your car is could you take a pic inside the boot to see how rod plated the floor to bolt through
Old Sep 28, 2023 | 12:13 PM
scoooby slayer
Will be a mission to see anything boot is full 😂🤣
Old Sep 28, 2023 | 12:16 PM
james kiely
haha ,nothing like a bit of weight over those back wheels carl
Danielbetty
13
May 25, 2013 02:34 AM
Jasesapphy
Sep 16, 2008 06:03 PM
Mr Sam
Aug 25, 2006 09:44 PM
