Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Mk3 Escort 1.6i cabriolet fuel entering oil
Old Apr 12, 2023 | 11:24 AM
LolHare's Avatar
LolHare
Default Mk3 Escort 1.6i cabriolet fuel entering oil
. My 1.6i cabbie won't start very well and is running rough, I had an oil leak and discovered that the oil was extremely thinned down with petrol, suffering from some kind of fuelling issue, it must have found a leak being too thin as I've changed the oil and the leak stopped, has anyone experienced anything like this please and can help at all?
Old Apr 12, 2023 | 11:39 AM
james kiely's Avatar
james kiely
i think the only way the fuel could get into the oil is if it's massively over-fueling. You need to get it set up right as it will do damage to your bores and bearings
Old Apr 17, 2023 | 10:09 AM
XR2's Avatar
XR2
There's a lot of reasons. Overfueling because of wrong set up, worn gaskets etc. inside the fuel distributor, worn and leaking injectors.
Plus worn piston rings are also a reason for fuel in the oil.
cameron2
Aug 19, 2010 06:05 AM
Ginge !
Nov 13, 2007 10:34 PM
kurdt5
Feb 20, 2007 07:52 PM
gus
Dec 27, 2004 11:31 AM
James Porter
Dec 16, 2004 08:23 PM
