1987 Escort 1.4
Old Mar 21, 2023 | 06:00 PM
FatPaps's Avatar
FatPaps
Default 1987 Escort 1.4
Hi All,
I am changing the alternator on my car but the new one has different connections. The original has a 3-pin connector ( marked B+ and D+ ) but the new one is different. I assume the B+ (red) wires can both go to the B+ terminal on the new alternator, I am not sure where the blue wire should connect to. The only other marked terminal is W ( warning lamp I guess ), but what is the other terminal in the black plastic area? Could that be D?
Thanks for any help.
Old alternator
New alternator (Ridex)
Wiring 3-pin connector
Old Mar 22, 2023 | 06:07 AM
haz87's Avatar
haz87
Reds to B+
Blue wire to D+ (the other connector in the black plastic - this is the exciter/dash circuit)
W is a pulse signal for Tacho's, and used by diesels generally - you don't need/use this
Old Mar 22, 2023 | 02:59 PM
FatPaps's Avatar
FatPaps
Originally Posted by haz87
Reds to B+
Excellent, that is perfect. Thank you very much sir.
Old Mar 28, 2023 | 03:26 PM
FatPaps's Avatar
FatPaps
OK so the alternator wires are good now, I have spent some time cleaning the engine while I had it in the garage. I did however forget to take a photo of the alternator bracket/bolts and how it fits the pulley that tensions the AC belt. Does anyone have a clear photo of that area so I can see?
carlatwork
Apr 20, 2020 12:03 PM
cosworth_wannabee
Nov 29, 2009 05:37 PM
cosworth_wannabee
Nov 28, 2009 04:45 PM
Bens2rs
Oct 24, 2008 10:06 AM
ScORTED
Oct 30, 2005 06:02 PM
