Injector??
Old Jan 29, 2023 | 06:04 PM
Focus st mk3 2.0's Avatar
Focus st mk3 2.0
Default Injector??
Hi guys. Have a 2.0 focus st 62 plate. I have fuel getting into the oil. Been told this could be a faulty injector.. or an issue with the fuel pump.. any ideas??
Old Feb 2, 2023 | 07:18 PM
stevieturbo's Avatar
stevieturbo
C**t
test them and see ?
or send them to be tested.
No, it is unlikely to be an issue with the fuel pump
Old Feb 2, 2023 | 08:12 PM
GVK.'s Avatar
GVK.
These do have a mechanical high pressure pump on the engine.
Old Feb 10, 2023 | 01:36 PM
Focus st mk3 2.0
Is there such a thing of an intermittent faulty injector?? Engin light comes on for few days then clears its self then comes back on.. coughs, stalls, smells of fuel when light is on. Could it b a MAF sensor??
Old Feb 10, 2023 | 02:27 PM
GVK.'s Avatar
GVK.
Need the codes reading especially if you've had an EML on. Does the oil smell of fuel?
Old Feb 10, 2023 | 03:27 PM
stevieturbo
C**t
Well if the CEL is on, scan it and see why.
Don't start firing a parts cannon, it's idiotic.
Test.
Old Feb 12, 2023 | 07:57 AM
scoooby slayer's Avatar
scoooby slayer
Test.
As above, the most important part about any repair is finding the fault, get codes read first
s2erst
Apr 27, 2012 12:29 PM
banhambuilt
Mar 24, 2007 11:47 AM
900ss
Dec 3, 2005 08:50 PM
rabbit 2004
Nov 26, 2004 10:30 AM
