2017 transit custom fuel pump issue
Old Jan 23, 2023 | 09:15 PM
Luis's Avatar
Luis
Default 2017 transit custom fuel pump issue
Hi, I'm having a nightmare with my 2017 transit custom 2.0 euro 6. The injector pump failed and 2 of my injectors went aswell so I had a garage replace the pump and injectors and recode the injectors but the van still won't start. I have also changed the pump in the tank just to be on the safe side. On my scanner when cranking my desired presure is 23000kpa but I'm only getting upto 17000kpa, I've pulled the return line off and with the ignition on there is fuel flowing out and it comes out alot faster when cranking, the fuel is coming from the return outlet from the injector pump if I block it with my finger and crank it it builds presure and starts, could the brand new pump be faulty? I've added a screenshot of the fuel coming out of the return from the pump with just the ignition on and not cranking. Any help would be great I need my van back.
Old Apr 17, 2023 | 09:49 AM
Abrar's Avatar
Abrar
Default Re-Pump
Hi Did you manage to get it sorted , as I’m having the same problem
nextural
Jun 15, 2018 06:46 PM
Trist
Apr 27, 2013 11:43 PM
stevedb
Jan 11, 2009 05:42 PM
Maxxeh
Nov 16, 2006 10:04 PM
big_wig_074
Feb 7, 2006 10:26 PM
