Wheels and Tyres Wheels and Tyres for all Ford's
16 inch wheels on Sierra Estate
Old Jan 13, 2023 | 12:10 PM
LukesWorkshop's Avatar
LukesWorkshop
Default 16 inch wheels on Sierra Estate
Hi all,
Got a Sierra estate on standard suspension. Currently running 14" steelies and was planning to go for some 15" alloys but I've came across some 16" ones which I like.
Just wondering if they'll fit without any arch modification and what size tyre I'd need to run.
Current tires are 185/65/14.
Old Jan 13, 2023 | 05:53 PM
BIG LEE's Avatar
BIG LEE
should go on without any issue running 195/45/16 or 195/50/16.. if you try running 205/50/16 it will catch on lock and maybe on bumps
Old Jan 13, 2023 | 05:55 PM
james kiely's Avatar
james kiely
What's the et and width of the 16-inch wheel luke?
Old Jan 13, 2023 | 08:22 PM
LukesWorkshop
Noted, thank you!
Old Jan 13, 2023 | 08:34 PM
BIG LEE's Avatar
BIG LEE
depending on alloy you want a et from say 35 to 45 you can fit up et48 but really you want closer to et35.. if there any less then 35 it may cause you issues no matter what tyre you fit
Old Jan 13, 2023 | 08:38 PM
LukesWorkshop
Will find out ASAP. All I know is they are 16" and the guy previously had them on his Capri. I've attached a photo for now.
Old Jan 13, 2023 | 08:54 PM
BIG LEE's Avatar
BIG LEE
there off a scorpio will go on no issues
mk22door
Jul 8, 2016 06:55 AM
sygjim
Apr 11, 2009 12:51 PM
V6PAUL
Mar 17, 2008 11:31 AM
Ryan_3
13
Jan 7, 2008 12:28 PM
