Wet Belts
Old Jan 10, 2023 | 10:47 AM
DaveMK's Avatar
DaveMK
Default Wet Belts
Im looking to buy a new car after an issue with a 1.0 ecoboost engine. Ive learned a lot about Wet Belts and the joy these can bring in the last couple of weeks.
Im trying to buy a used Smax or Galaxy and want to avoid engines that have this set up.
How can you check?
Old Jan 18, 2023 | 06:10 PM
stevieturbo's Avatar
stevieturbo
C**t
I think it would be safe to avoid anything with any 1.0 ecoboost engine. Are they not very troublesome ?
Old Jan 18, 2023 | 06:55 PM
GVK.'s Avatar
GVK.
Even the 1.8 later engines have a wet lower belt , so be careful.
Old Jan 22, 2023 | 07:38 AM
The father in law has a 1.0ltr Ford ecosport with these engines in. So far its been OK. You have to use the correct oil,last time I serviced his the oil supplied was 5/20 instead of the usual 5/30
Fil
Oct 1, 2008 01:42 PM
THE RADMAN
Ford Escort RS Cosworth
Mar 29, 2006 03:41 PM
*Anna*
11
Jan 11, 2005 05:12 PM
