Ford sierra running problem
Old Jan 2, 2023 | 09:04 PM
Jonny1988's Avatar
Jonny1988
Default Ford sierra running problem
I own a 2.0 dohc efi sierra sapphire, i have changed map sensor, idle control valve, ecu coolant temp sensor, air temperature sensor, leads and plugs, throttle position sensor.
It runs rough and wont take throttle, sometimes it won't start, does anyone have any ideas? I heard theres a specifc way to fit throttle position sensor?
Old Jan 18, 2023 | 06:14 PM
stevieturbo's Avatar
stevieturbo
C**t
Don't throw the parts cannon, it's just stupid.
Amazon Amazon
Old Jan 18, 2023 | 07:00 PM
scoooby slayer's Avatar
scoooby slayer
https://www.amazon.co.uk/Automotive-...dp/1859603440/
Gotta agree with Stevie here need to work out what's wrong rather then just keep changing parts
Have you worked out exactly why it doesn't start ?
Old Jan 18, 2023 | 07:17 PM
BIG LEE's Avatar
BIG LEE
As above sadly.. take it to someone who knows about stuff or go through it prop.. when you change aload of parts you end up wasten money and alot of time
Old Jan 18, 2023 | 07:27 PM
stevieturbo
C**t
The haynes manual I linked to will cover a lot of basics to help you learn how things work, and then how to test them
Thorn.RS
Jan 30, 2022 09:56 AM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
tore_tj
Ford Escort RS Cosworth
18
Oct 22, 2008 08:44 AM
