Connector Pin Help
Old Nov 8, 2022 | 08:30 PM
Jeffspop's Avatar
Jeffspop
Default Connector Pin Help
I need the top pin, I've tried the lower ones, see the codes and they are about 1.2mm too long and do not lock in. Anyone have the correct part number.. For the EDIS connector and the OS sensors 1998 scorpio. many thanks
Old Nov 12, 2022 | 08:18 PM
stevieturbo's Avatar
stevieturbo
C**t
For EDIS, look for the Megasquirt and Megajolt guys, as they use that stuff a lot.
Or this FB group has a superb ability to locate sources
https://www.facebook.com/groups/4359499570789592
This crowd to MS stuff
https://trigger-wheels.com/store/index.html
Although they do also look very like the quite common superseal 1.0 series as per many aftermarket ecu's these days. Just depends on their dimensions
https://www.shopbhp.com/products/ecu...superseal-null
https://uk.rs-online.com/web/p/autom...minals/6809705
neilsrsturbo
Jul 22, 2012 07:43 PM
PDH11R
22
Jan 11, 2006 05:37 PM
xr4x4rs
Apr 1, 2005 04:54 PM
Wazzzer
Nov 23, 2004 10:14 AM
