2wd Front brake clearing for wheels
Old Oct 8, 2022 | 08:23 PM
Dreeeze's Avatar
Dreeeze
Default 2wd Front brake clearing for wheels
Hi!
3 door cosworth, standard brakes , 4 pot caliper
Can anyone measure the distance from the caliper outer edge to the mounting surface on the brake disc where you mount the wheel?
Need to know if this new wheel spoke will fit without hitting the brake caliper
Old Oct 9, 2022 | 05:09 PM
cossynut2's Avatar
cossynut2
10 Year Member
Originally Posted by Dreeeze
Hi!
If the new wheels are the same size and the offset is the same as what is currently fitted they should clear the calipers ok. Can you not do a trial fit on one to check?
Old Oct 9, 2022 | 06:25 PM
Dreeeze's Avatar
Dreeeze
The car is in storage, far away, and thinking about buying these wheels, så dont want to buy then , and they dont fit :P ? , so need the mesurement how much the front calipter builds beyond the surface on the hub
Old Oct 14, 2022 | 01:14 PM
cossynut2's Avatar
cossynut2
10 Year Member
My car is a 2wd Saff which has already had HI-Spec big brakes fitted so no help to you, I am sure if you post up your question to 3 door Cosworth owners one of them will be able to give you the measurements you need.
trev0006
Aug 13, 2008 01:24 PM
3001paulh
Ford Escort RS Cosworth
May 1, 2007 03:15 PM
D7AKE
Dec 16, 2006 06:21 AM
Spiky
Aug 19, 2005 10:02 AM
