1988 ford escort xr3i
Old Apr 7, 2022 | 06:03 PM
philread's Avatar
philread
Default 1988 ford escort xr3i
hi there i just brought a mk4 xr3i cabby and it needed a new fuel pump witch ive had done its been running fine til now.
it wont run on idle its the cvh engine and for the life of me i cant think what it could be so looking for some help.
Old Apr 8, 2022 | 02:55 PM
XR2's Avatar
XR2
Like I mentionend in the other thread: make sure it's the right fuel pump.
Change the fuel filter. K-Jetronic is very sensitive when it comes to fuel pressure and an old filter might cause a lot of problems.
Does it run fine but just cuts out on idle? Then check the ignition (6° unleaded) and try to rise the idle speed (screw on top of the throttle body).
Old Apr 8, 2022 | 02:58 PM
philread's Avatar
philread
ill have a look i have got it from the reg in a motor factors
Old Apr 8, 2022 | 04:33 PM
XR2's Avatar
XR2
There's only one fuel pump that fits as the Escort 4 had plug-on terminals, most others had screw-on.
Bosch 0580254941. And do yourself a favour and buy ONLY Bosch parts. Aftermarket pumps often cause trouble.
Capri 2,8i, Escort 3 and Sierra 1 had 0580464125
Granada 2 2.8i had 0580254975
Escort 4 is the most expensive, Bosch at aftermarket dealers ~210 Euro; Granada 2 costs about 220 Euros; Capri/E3/S1 is the cheapest with 80 Euros.
You can use the cheaper Capri/E3/S1 pump, just have to modify your wiring a little bit.
mercury grey minter
Apr 8, 2022 03:54 PM
Rihards Skrubis
May 16, 2013 01:08 PM
GiugiaroFan
12
May 11, 2013 03:51 PM
Mossy XR2 Turbo
Feb 11, 2011 05:11 PM
