Where Does this Bolt, Nut, Clip or thingy go - Guide
Old Mar 7, 2022 | 08:18 AM
Jack and the Beanstalk's Avatar
Default Where Does this Bolt, Nut, Clip or thingy go - Guide
Hi All
Am at wits end with this. Trying to catelogue the fastners from scratch. Please can the wizards help me with identifying. The online parts diagrams don't really show you nicely what the part looks like and some list various types.
I realize that these bit could be used at various locations but at least to have some idea.
If you know any info that is related to the part please update the post
going to mark it down using fastener # codes.
Where Does this go or used:
# 01 fastener clip
Info:
location: I think it goes somewhere on the dash not sure?
End of post.
Old Mar 7, 2022 | 08:35 AM
Where does this go or used
# 02 fastener clip
Info: Pal 9, M8, lock nut, speed clip
End of Post
Old Mar 7, 2022 | 08:49 AM
Where does this go, used?
# 03 fastener clip
Info: 35 EW, speed clip. Has no machined thread. Maybe used with a screw?
End of post.
Old Mar 7, 2022 | 09:00 AM
# 04 fastener clip
Info: has a machine thread, speed clip nut
End of post.
Old Mar 7, 2022 | 09:24 AM
Where does this go or used?
# 05 Fastener clip
Info: not sure
End of post.
Old Mar 7, 2022 | 09:32 AM
# 06 Fastener clip
Info: inverted 8 GR 4 speed clip nut. No machined thread, possibly used with screw
End of post
Old Mar 7, 2022 | 01:49 PM
Identified & Confirmed
# 07 fastener clip
Info: MCS clip, has grippy teeth on one end
Location: B-pillar for holding the plastic interior trim.
End of post.
Last edited by Jack and the Beanstalk; Mar 26, 2022 at 01:52 PM. Reason: Update of fastener location - 09-03-2022, 10:29 AM / JATB confirms
Old Mar 7, 2022 | 01:59 PM
# 08 fastener clip
Info: has machine thread / M6 Thread
Location: Lower window wiper bracket. Fastens the mech onto body / scuttle.
End of post.
Old Mar 7, 2022 | 02:06 PM
# 09 fastener clip
Info: clip thingy
End of Post.
Old Mar 7, 2022 | 02:12 PM
# 10 fastener clip
Info: speed clip, no thread, screw type?
Location: TBC, possibly 3 x center console rear bracket & 2 x center console front bracket
End of post.
Old Mar 7, 2022 | 02:21 PM
# 11 fastener clip
Info: E/F W 6.5, speed clip, screw type no machine thread
End of post.
Old Mar 8, 2022 | 08:25 PM
# 12 fastener bolt
Info: M12 x +/- 110mm long, Atlas, 8.8, M
Location: Rear suspension main beam bolt, shank and thread lengths are different
End of Post.
Last edited by Jack and the Beanstalk; Mar 26, 2022 at 02:06 PM. Reason: Update of fastener location - Marc sierra 09-03-2022, 10:26 AM / JATB confirms
Old Mar 8, 2022 | 08:45 PM
# 13 fastener bolt
Info: M10 x +/- 75mm, Verbus, 8.8
End of Post
Last edited by Jack and the Beanstalk; Mar 26, 2022 at 02:00 PM. Reason: Update of fastener location - Marc sierra, 09-03-2022, 10:23 AM
Old Mar 9, 2022 | 08:22 AM
Marc sierra's Avatar
Marc sierra
# 09 fastener clip
Info: clip thingy
End of Post.
I think this is holding the cable for the bonnet release near the slam panel.
Old Mar 9, 2022 | 08:23 AM
Marc sierra
# 13 fastener bolt
End of Post
I’d say the rear upper shock mounts.
Old Mar 9, 2022 | 08:26 AM
Marc sierra
# 12 fastener bolt
Location: either back or front of suspension main beam bolt, shank and thread lengths are different TBC?
End of Post.
I would think the main bolt for the rear beam. The bolts on the front are pointy and this one is not.
Old Mar 9, 2022 | 08:29 AM
Marc sierra
# 07 fastener clip
End of post.
They look like the clips that are on the B-pillar for holding the plastic interior trim.
Old Mar 9, 2022 | 09:23 AM
Thanks Marc I'll check your recommendations any info is welcomed 👍
I have a plenty more additions to add to this thread builders can expand on or advise will be of great help and assistance
cheers
Old Mar 9, 2022 | 09:30 AM
# 14 fastener bolt
Info: M8 x +/- 35mm, shanked, GSF, 10.9
End of post.
Old Mar 9, 2022 | 09:36 AM
# 15 fastener spacer
Info: round spacer, OD 24mm x ID 8mm x L 20mm
End of post.
Old Mar 9, 2022 | 09:45 AM
# 16 fastener bolt
Info: M6 x +/- 20mm, Boesner, 8.8, has built-on washer
Old Mar 16, 2022 | 08:10 PM
# 17 fastener bolt
Info: M8 x +/- 25mm thread extend to 32mm, Graeka, 8.8, has built-on washer
End of post
Old Mar 16, 2022 | 08:18 PM
# 18 fastener bolt
Info: M8 x +/- 16mm, Atlas 8.8, full thread
Location: Parking / Hand Brake Lever 2 x securing bolts
end of post
Old Mar 16, 2022 | 08:33 PM
# 19 fastener bolt
Info: M6 x +/- 20mm extends to 25mm, Graeka, 8.8, has built-on washer
End of post
Old Mar 16, 2022 | 09:23 PM
# 20 fastener nut
Info: M12 slotted / castle nut, MF 181
End of Post
Old Mar 16, 2022 | 09:47 PM
# 21 fastener bolt
Info: M12 × 80mm, hex cap, shank with lock nut and washer spacer, 10.9
Location: Prop-shaft rubber insulator / coupling / bush /donut x 3 set, gearbox output side, damper
End of post
Last edited by Jack and the Beanstalk; Mar 26, 2022 at 01:40 PM. Reason: Update of fastener location - Marc Sierra, 23-03-2022, 05:50 PM
Old Mar 16, 2022 | 10:08 PM
# 22 fastener spacer
Info: slotted spacer hat, OD 17 x ID 10 x L16mm
End of post
Old Mar 16, 2022 | 10:12 PM
# 23 fastener spacer
Info: spacer, OD 18 x ID 10 x L 17
End of post
Old Mar 17, 2022 | 05:32 PM
Identified & Confirmed.
# 24 fastener bolt
Info: M8 x 25mm triangular thread flange bolt, ML
spacer, OD +/- 25 x ID 8.5 x t 4mm
Location: front seat to floor pan anchor fasteners. Each side retains 5 x bolts 1 of which has a smaller Dia washer-spacer
End of post
Last edited by Jack and the Beanstalk; Mar 26, 2022 at 01:48 PM. Reason: Update of fastener location - Marc Sierra, 23-03-2022, 04:23 PM / JATB confirms
Old Mar 17, 2022 | 06:19 PM
# 25 fastener bolt
Info: M11 thread x 29.5mm torx, BH, UNF, S flat round head
Location: front seatbelt height ajuster bolt to B-pillar
end of post.
Old Mar 17, 2022 | 07:43 PM
# 26 fastener bolt
Info: M8 x 21mm pan head torx short shoulder bolt
End of post
Old Mar 23, 2022 | 02:20 PM
Marc sierra
# 16 fastener bolt
I think these are used for the grounding points of the wiring loom.
Old Mar 23, 2022 | 02:21 PM
Marc sierra
# 26 fastener bolt
End of post
I think indeed the brackets for the rear seats.
Old Mar 23, 2022 | 02:23 PM
Marc sierra
# 24 fastener bolt
End of post
Probably for mounting the front seats.
Old Mar 23, 2022 | 02:26 PM
Marc sierra
End of post
Not really sure, but they look like they go into the bracket for the power steering pump, for mounting the pump.
Old Mar 23, 2022 | 03:50 PM
Marc sierra
# 21 fastener bolt
End of post
I’m quite sure these go on the prop shaft to the rubber bush on the output of the gearbox.
Old Mar 26, 2022 | 11:31 PM
Does anyone havea close up of the bolt or screw set for the bonnet catch release Mechanisim? It Mensions 3 but i count 4 locating holes. 2 on each side. 1 on top hole of support bar and 1 on bottom hole of support bar, M6 by 10mm seems rather short?
No 6 Screw - Pan Head to 28.02.1993, / 1640182 Screw - Self-Locking 3.00 M6 X 10MM
To be confirmed
JamesH
Mar 9, 2011 08:09 AM
dojj
PassionFord FAQs
Apr 17, 2010 02:13 PM
Rs Baz
Jun 11, 2006 05:29 PM
mr boost
16
Oct 11, 2005 06:27 PM
spenner
Jul 12, 2005 09:34 PM
