Sierra pinto to DOHC EFi
Old Feb 8, 2022 | 06:35 PM
Insima_RS's Avatar
Insima_RS
Default Sierra pinto to DOHC EFi
Hello everybody and greetings from Croatia!
I'm having a bit of problem figuring site out, so I'm sorry if I posted in wrong section.
I'm after some advice,help.
So, as the title says, I'm transplanting DOHC EFi engine in carb pinto Sierra. Donor car is 1990 Sierra Carvan 2.0 DOHC CL, and project car is 1988 hatchback Sierra Ghia.
I'm having wiring problem, specifically the ECU loom. On donor car ECU loom connects to the car loom via 3 jacks behind battery. I dont have those jacks on the loom of a project car. So, my question is, is it possible to connect ECU loom on existing loom of a project car? Can I separate wiring required for ECU to run and swap it over to the existing loom of a project car? Any help is much appreciated, and sorry for my bad english🙂
FlashRS
Apr 7, 2013 09:34 PM
robgee32
Jun 13, 2010 08:18 AM
daveugc
Nov 28, 2008 03:28 PM
dojj
Oct 22, 2005 09:04 PM
Hofajoab
Jul 31, 2004 09:53 PM
