Ford Focus 2.0 2007 - ESP system fault U2023
Hi.
My car is going in to limp mode, and I have no idea what is causing it.
The error codes I have is:
P0578 - Cruise Control Multi-Function Input A Circuit
P2135 - Throttle/Pedal Position Sensor/Switch A/B Voltage Correlation
U2023 - Vehicle Communication Network Fault
U1900 - CAN communication bus fault
C1750 - Accelerator Position Sensor Out of Range
B1300 - Power door lock circuit failure
B2477 - Module Configuration Failure
P0581 - Cruise Control Multi-Function Input A Circuit High
Any idea what to do?
paceo
14
Mar 28, 2007 04:31 PM
