Engine mounts Sierra cosworh
Old Aug 13, 2021 | 11:17 AM
1986rs's Avatar
1986rs
Default Engine mounts Sierra cosworh
Hi guys ,,
have to change out engine mounts on my 3 door.
can this be done without removing the engine.?
my idea was to use an engine crane to lift the engine and support it .
is this all possible, is it best to remove the arms that bolt onto the block ?
thanks
Old Aug 16, 2021 | 08:23 PM
stevieturbo's Avatar
stevieturbo
C**t
If you cannot jack it up enough to get them out, you could maybe unbolt the cradle and drop it down a little
THE RADMAN
Oct 22, 2010 01:04 PM
cossie330
Jun 1, 2009 05:25 PM
cossie_baz
May 27, 2005 07:31 PM
