mk7 transit pedal to the floor after new brake pipe
ive already asked on the transit forum but thought u guys know ur stuff so why not ask here aswell
i changed a few brake pipes on my tranny, tried to just do a pressure bleed but no luck so used forscan and all seemed to got well, seemed to, i do have brakes but the pedal is almost on the floor before any response from the brakes
i let a good amount of fluid come through before switching to the next wheel so i assumed the air was all out, am i right in saying there must still be air in the system if i have so much travel before any bite?
the pressure bleeder was set to 10psi not that would make much difference
thanks for any help
so do i need to bleed more?
thanks for any help
messcortmk6
Sep 20, 2007 06:43 PM
Adam_BlackRS
11
Jun 29, 2005 07:34 AM
