ford sierra lhd to rhd is it possable
Old May 15, 2021 | 01:39 PM
evolution2's Avatar
evolution2
Default ford sierra lhd to rhd is it possable
hi everybody is it possable to change a sierra sapphire from lhd to right hand drive the car is a 2.0 ghia thanks
i want to do this because the car is rust free
Old May 16, 2021 | 08:31 PM
stevieturbo's Avatar
stevieturbo
C**t
if you have all the parts...of which there would be very many, and can alter or replace the wiring loom etc.....of course it would be possible.
Some minor chassis mods may be needed for bolt holes etc.
And likes of headlights would need changed for RHD
Old May 16, 2021 | 09:33 PM
evolution2's Avatar
evolution2
ok thanks i wounder would the bulk head need to be changed also?
Old May 16, 2021 | 09:37 PM
stevieturbo
C**t
I doubt it, they're built in same way and usually universal for either, just some holes etc likely not drilled.
Old May 17, 2021 | 07:55 AM
smiley's Avatar
smiley
Battery tray fuse box brake servo all on opposite side steering colum brackets opposite side is easier to change bulkhead if car is being stripped I'm doing a 3dr I take it your doing a reshelling
Old May 17, 2021 | 04:46 PM
evolution2's Avatar
evolution2
its not a reshel just would rather it rhd! if i have to change the bulk head ill leave it lhd would be to much work id need a parts car then also.
thanks for the reply
Old May 23, 2021 | 10:10 PM
BIG LEE's Avatar
BIG LEE
It can be done but its a chew on to do it right as changen bulk head by drilling spot welds you will end up pickn inner wings and chassis legs off etc etc.. im sure someone on turbosport done it with photos etc
johnyfiesta
Jun 16, 2012 10:54 PM
rscostalot
25
Dec 24, 2007 09:01 PM
josenovo
14
Jul 3, 2006 01:49 PM
