2.0 dohc twincam sierra , smokey under load ?
Old May 8, 2021 | 05:53 PM
Ed1994's Avatar
Ed1994
Default 2.0 dohc twincam sierra , smokey under load ?
Just doing up a sierra 2.0 dohc , was converted from a cvh 1.8 originally, cars up and running but smokey when drove hard or revved up hard , otherwise running well, seams like dark blueish smoke and at times nearly black, not sure if the air fuel ratio mite need to be set ? Or if its burning oil ? Any ideas thanks
Old May 8, 2021 | 08:18 PM
The Black Count's Avatar
The Black Count
Had one several years ago which did the same, ended up failing the m.o.t as they said it was burning too much oil. I suspect its the same and probably the valve stem seals
Old May 8, 2021 | 08:25 PM
Ed1994's Avatar
Ed1994
Do you remember Was yours smokey from start up and at idel , or just when under load
Old May 9, 2021 | 10:00 PM
The Black Count
My memory not that good, but if I remember correctly it smoked all the time and was a common problem. It is not really a good engine so time to consider a zetec swap.
Ed1994
May 8, 2021 05:50 PM
mirkules
May 30, 2008 04:52 PM
cossiemen
Feb 12, 2005 06:23 PM
