Seam/stitch welding road use Sierra
Old Apr 14, 2021 | 08:06 AM
carbon1993's Avatar
carbon1993
Default Seam/stitch welding road use Sierra
Anyone who has a sierra that is seam/stitch welded ford Sierra without a cage?
does it make sense to do this to a road car without a cage?
Old Apr 14, 2021 | 06:37 PM
stevieturbo's Avatar
stevieturbo
C**t
For a road car, such intrusive and labour intensive work would be totally pointless.
Every weld, is another opportunity for rust.
Old Apr 14, 2021 | 08:21 PM
carbon1993's Avatar
carbon1993
The car is completely bare metal and the joints are clear. It would only take time to do the welds.
It indeed could be a point to start rust. But the car will be thermal zinc sprayed. So it would need to go through that sacrificial layer first. The car will be overloaded with anti rust/preventive stuff when it's hanged in a hoop, so that stuff will get everywhere.
Just want to know if it is worth to do it. and if you can feel the diffrence. I know the chassis of these things are very weak.
Old Apr 15, 2021 | 07:55 AM
cossynut2's Avatar
cossynut2
10 Year Member
You have said it will be a road car so you won't be driving it like a track car so I doubt if it will be something that would make any difference.Sounds like you will end up with a very good road car once it is all finished.
Old Apr 15, 2021 | 06:21 PM
stevieturbo
C**t
If it's already completely bare metal, and you've the time etc....then I see little reason not to do it ? I'm sure it can only be a benefit if done well.
It'd be a different story if you were doing it to an already painted/sealed shell.
Roman123
81
Jun 17, 2014 08:39 PM
langer
Aug 6, 2011 01:55 AM
kouzman
20
Dec 1, 2006 09:11 PM
_DAN_
Feb 14, 2006 10:46 PM
