Engine Oil Temp Sensor
Old Apr 8, 2021 | 06:44 PM
adduk's Avatar
adduk
Default Engine Oil Temp Sensor
Can anyone point me in the right direction for where i can get an oil temp sensor to be used for the ECU? Ideally i want one with the two pin plug like used on the injectors etc.
Cheers All
Old Apr 8, 2021 | 08:38 PM
GVK.'s Avatar
GVK.
What ecu/car.
Old Apr 8, 2021 | 09:18 PM
adduk's Avatar
adduk
It’s on a zetec in a series 2 running. Maxxecu. Just need a two wire resistive sensor which can be scaled in the Ecu with the standard plug like in the injectors etc. Hoping someone has used one recently at a reasonable price and can let me know which one it is. I know there is a haltech one advertised which would work but it’s Ł60 which I thinks quite steep or am I just been tight! Lol
Old Apr 8, 2021 | 09:42 PM
stevieturbo's Avatar
stevieturbo
C**t
A lot depends where you want to fit it or screw it into.
Most coolant temp sensors will be fine.
Old Apr 8, 2021 | 11:27 PM
Rsmat's Avatar
Rsmat
Efi parts
Old Apr 9, 2021 | 07:34 PM
Ridgey's Avatar
Ridgey
Bosch motorsport sensor.
cossiestu
Jun 1, 2017 08:11 PM
SřrenBM
Aug 5, 2004 01:08 PM
Toe Knee
Nov 16, 2003 06:45 PM
