Mk Indy kit car with dohc engine
Old Mar 20, 2021 | 11:46 AM
Compy's Avatar
Compy
Default Mk Indy kit car with dohc engine
Hi I recently got an mk Indy with the Ford 2.0l DOHC engine that I know nothing about other than been told it is a Sierra engine and I need to find out if it is 8 or 16v any ideas? And need to change cam cover gasket
I want to get more power from it but have been told I’m better off swapping it out for a Ford zetec st170 engine is there really nothing I can do to get more power out of the old irl
Old Mar 20, 2021 | 02:47 PM
Canada1's Avatar
Canada1
Post some pictures. Help will arrive shortly after.
Old Mar 20, 2021 | 07:02 PM
XR2's Avatar
XR2
It's a DOHC 8 (EIGHT!) valve engine. Usually 120-125 bhp on standard setup.
Old Mar 20, 2021 | 09:09 PM
GVK.'s Avatar
GVK.
They were never very tuneable back in the day.
So your advice on swapping it out would be right.
Old Mar 20, 2021 | 10:46 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
the scorpio 16 valve engine would be a reasonably straight swap as they use the same block, you can get them in 2.0 or 2.3. it's a heavy engine though, you'd be better off going for a zetec. you'd probably save somewhere in the region of 10-15kg i bet.
Old Mar 20, 2021 | 10:52 PM
Compy's Avatar
Compy
been told to look out for a st 170 zetec donor car and that they are a better engine to modify but how easy would it be to swap it out with the DOHC wording ecu etc any ideas
Ellis1990
32
Aug 5, 2013 11:18 PM
-beefy-
Ford Mondeo Including ST
Nov 26, 2006 08:54 PM
-beefy-
Nov 23, 2006 06:50 PM
russel7.wanadoo.co.uk@fs
Jun 28, 2005 09:52 PM
