Restore stable handling with new struts + Installation Video
The suspension system keeps your car up off the ground and protects you and your passengers from significant bumps and bruises. A network of struts, springs, and shock absorbers is responsible for keeping this area in top shape. If you're experiencing poor ride quality and handling, give your suspension system a reboot with Monroe Strut Assembly.
This innovative unit is the first complete, ready-to-install replacement strut assembly. It comes with all the components required for strut replacement in a single fully-assembled unit. It features a pre-assembled replacement bearing plate, upper and lower spring isolators, upper spring seat, coil spring, boot kit, and a premium strut.
Our tech expert Greg is back in the shop with a 2010 Ford Expedition to show you how to perform the strut replacement on this SUV. Watch our step-by-step instructions on how to get the job done and restore the suspension of your ride!
Monroe® - Quick-Strut™ Complete Strut Assembly
https://www.carid.com/2010-ford-expe...611865524.html
MOOG® - Problem Solver™ Front Upper Non-Adjustable Control Arm and Ball Joint Assembly
https://www.carid.com/2010-ford-expe...074940251.html
MOOG® - Stabilizer Bar Link
https://www.carid.com/2010-ford-expe...063121406.html
Farmer Giles
Feb 14, 2013 09:01 AM
steve.rst
PassionFord Swap Shop.
Sep 3, 2011 08:25 AM
B19-TRB
Oct 6, 2004 09:07 AM
