1992 Sierra cosworth
Old Feb 4, 2021 | 07:08 PM
Cossysaph's Avatar
Cossysaph
Default 1992 Sierra cosworth
Hi lads currently doing a swap of a 2.9 bob for a YB few things i want to ask
What ecu do people recommend, looking for something easily tunable
with that is there any injectors/ fuel pump people recommend or will the standard ones do?
also while I'm here is there anything else people recommend changing while I have it out.
Thanks.
Old Feb 4, 2021 | 10:03 PM
martysmartie's Avatar
martysmartie
Weber L8 will do everything you need, you can get a modern ECU but it would be overkill imo.
944 (standard) or 044 for a pump, again opinions vary with injectors, I would go for Siemens 55LB, but depends on what you have in mind.
They are known for having a better spray pattern than the OE (i.e. Bosch)
Martin
Winter78
11
Apr 16, 2021 05:08 PM
darryl turbo
Jan 11, 2009 06:07 PM
Rossco
29
Sep 26, 2007 02:01 PM
joo5ty
Aug 20, 2007 03:27 PM
scooby_hater
Feb 10, 2006 06:56 PM
