Does anybody know where I could find a t34 acutuator bracket or if my t3 bracket will fit on the t34? I’ve tried CR turbos and they don’t sell them anymore thanks in advance
Iirc the t34 doesn’t actually have an actuator bracket as where the actuator bolts onto the t34 it’s part of the actual turbo housing.
correct me if I’m wrong as it’s been a few years since I’ve owned my Sapphire Cosworth, but I seem to recall when I changed my t34 for a gt30, the gt30 came with an actuator bracket which I had to get modified for the actuator to sit at the correct angle. The t34 had a mount built into its housing where the actuator bolted onto it. I’m 99.9% sure this was the case
like this picture, where the actuator sits is part of the turbo housing itself
Reason: Addition
Doesn’t work on a 2wd as you need to rotate the turbo housing which then makes the actuator bracket that is moulded to to turbo no long in line I’ve sused it how with a t4/gt28 actuator bracket
