Standard ABS Master Cylinder in a 2WD Cosworth
Hi Guys
Can I use the Standard ABS Master Cylinder from a 2.0L DOHC Sierra in my 2WD Cossie? I'm having some problems with the unit even after rebuilding it...
Is there a problem because of the 4 pot in the 2WD cossie VS the 2 pot in the Standard/4x4 ones?
I've read somewhere that they are not compatible and it will make the pedal travel a lot more but haven´t found any info on that.
Can someone help?
Thanks
Can someone help?
Thanks
Yes you can use the ABS master cylinder from a standard DOHC Sierra. I also use one in combination with Cosworth 2wd brakes and it works perfectly. The front calliper pistons are around the same size and the rears are exactly the same.
Marc sierra
Sep 11, 2013 09:18 PM
