Escort RS1600i This forum is for all things about the Escort RS1600i
Escort RS1600I misfire
Old Jan 27, 2021 | 05:13 PM
Lloris22's Avatar
Lloris22
Default Escort RS1600I misfire
Can anyone tell me where the ECU temperature sensor is please?
Many thanks
Old Jan 27, 2021 | 05:45 PM
XR2's Avatar
XR2
Underneath the inlet manifold. On the underside of the flange that holds the injectors and sits beween the inlet manifold and the cylinder head.
It's a standard sensor you should still get nowadays.
Old Jan 27, 2021 | 05:55 PM
Lloris22's Avatar
Lloris22
Excellent, cheers
Old Jan 27, 2021 | 06:02 PM
XR2's Avatar
XR2
Vdo 323805001005n
Old Feb 24, 2021 | 08:00 PM
slider's Avatar
slider
unlikely to cause a missfire
have you changed Ht leads? could also be a plug or coil breaking down when warm
Old Mar 13, 2021 | 12:04 PM
Lloris22's Avatar
Lloris22
Default RS1600I
Hi
Has anyone got an ignition temperature sensor that I could borrow or buy, need to see if this is causing the misfire. Goes into the inlet manifold
thanks Mark
Old Mar 15, 2021 | 01:19 PM
XR2's Avatar
XR2
Originally Posted by XR2
Vdo 323805001005n
Still available and not expensive.
Lloris22
Escort RS1600i
Jan 7, 2021 08:00 AM
Coney1982
Escort RS1600i
Apr 22, 2017 06:29 PM
RS Juto
Aug 10, 2007 05:13 PM
