Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
MK3 Fiesta with CVH 1.6 engine compression low in 2 cylinders.
Old Dec 24, 2020 | 02:31 PM
Fiestamk31.6cvh's Avatar
Fiestamk31.6cvh
Default MK3 Fiesta with CVH 1.6 engine compression low in 2 cylinders.
Smoke coming out the back too, what is the best thing to do?
C1 - 110
C2 - 120
C3 - 155
C4 - 150
Could this be pistons or HG? What is the best way to troubleshoot?
I did not do the engine swap but would a zetec drop straight in?
Old Dec 24, 2020 | 02:59 PM
GVK.'s Avatar
GVK.
Could be valves /pistons, if head gasket the reading would be less.
leak down test required
Old Dec 24, 2020 | 03:05 PM
Fiestamk31.6cvh
What is the best way to troubleshoot this?
Old Dec 24, 2020 | 03:33 PM
GVK.'s Avatar
GVK.
Old Dec 24, 2020 | 04:11 PM
Fiestamk31.6cvh
May change the head gasket anyway car is smoking so need to change the seals. While i am doing that how can i check the pistons?
Also, the car does not have any coolant hoses going to the heater core, how would i route the cooling hoses into the cabin?
Prickly_buzz
Apr 2, 2017 03:46 AM
liamT74
17
Nov 17, 2015 04:50 PM
Gingerwatson
Fiesta RS1800/RS Turbo
Mar 26, 2007 08:25 AM
Philly_F
Mar 24, 2006 06:09 PM
