chrome window trim, removable?
I'm painting the car and would like to remove the outer window rubbers, I was also going to satin black the chrome trims.
is it possible to remove them without destroying them? is there an alternative all black rubber replacement?
cheers for your help guys.
Hi the chrome/alloy trim is part of the rubbers it wont come off them easy and if it did the smallest kink or twist will kill them.. i would leave them on rubbers as one but even then you have to take care for them twistn about
