Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
lights on warning buzzer
Old Nov 25, 2020 | 06:07 PM
johnno23's Avatar
johnno23
10 Year Member
Default lights on warning buzzer
Hi guys, does anyone know if the lights left on warning bell when opening the door, is covered by a fuse as mine on my MK2.5 focus has stopped working?
thanks in advance,
johnno
Old Nov 25, 2020 | 06:34 PM
GVK.'s Avatar
GVK.
Does the interior light work off the drivers door?
Might be a door ajar switch fault or broken wires to a pillar.
Old Nov 26, 2020 | 03:43 PM
johnno23's Avatar
johnno23
10 Year Member
Default lights on buzzer
Hi GVK, yes the interior light does come on when door opens.
regards
johnno
Old Dec 11, 2020 | 11:17 PM
mgmidget's Avatar
mgmidget
check switch
Old Dec 12, 2020 | 05:29 PM
johnno23's Avatar
johnno23
10 Year Member
HI MGMIDGET, thanks for reply, you say check switch, not being familiar with the layout of the car and checking manual could you possibly enlighten me as to where the switch is located.
thanks in advance,
Johnno.
Old Dec 12, 2020 | 11:58 PM
mgmidget's Avatar
mgmidget
A few weeks ago my front foglights stopped working the fuse was ok, so i took the headlight switch out i had to take off bottom panel drivers side then above the switch is a airvent that needed to be removed just pops off underneath was some screws took them out and whole switch comes out. i found the wire by going through the haynes mauakl worth its weieght in gold put multimeter across the terminals hey presto front fogs back now i didnt notice if the buzzer had stopped working i took the switch to bits has i couldnot get the same switch as being rare as rocking horse poo tryed ebay waste time looked at the tube lol found video how to dissasemble switch put the switch back together no bits left over lol pushed the switch pins into the conector and i noticed black charred plastic on 1 pin obviously the pin drawed to much current and melted some of the connector plug i cleanded it off the pin and plug and everythink worked a treat try the switch check the pins for black melted crap
Old Dec 13, 2020 | 12:30 PM
johnno23's Avatar
johnno23
10 Year Member
Hi mgmidget, thanks for the detailed reply, now I know where to look will remove light switch and investigate from there.
cheers mate,
Johnno
johnno23
Nov 23, 2020 07:30 PM
Stautz
Aug 1, 2017 09:27 AM
Combi_Chris
Nov 22, 2005 12:20 AM
