St170 ticking and engine shaking
Old Oct 26, 2020 | 09:14 AM
Ashley Howard's Avatar
Ashley Howard
ST170
Default St170 ticking and engine shaking
Hey all
my st170 has had top end rebuild after head gasket had gone .. everything is tourqe up and put back how it should and has been timed up
yet it's still making such a racket
Loud ticking noise with it shaking
Any help would be great
Old Oct 26, 2020 | 09:20 AM
haz87's Avatar
haz87
I know you say its been timed, but from that description if its only the head thats been touched, its timing...
Old Oct 26, 2020 | 09:27 AM
Ashley Howard
ST170
I tried to upload video but it wont let me... I'll retime it again and go from there ...
it's also a pain to start takes a good 4 turns on the key
Old Oct 26, 2020 | 09:31 AM
Ashley Howard
ST170
I uploaded video to YouTube so you can see what I mean
Old Oct 26, 2020 | 10:53 AM
haz87's Avatar
haz87
Thats mistimed or you've got a dead cylinder. Check all injectors are firing and all spark plugs are sparking. Compression check too if you've got the kit just to be sure.
Old Oct 26, 2020 | 10:56 AM
haz87's Avatar
haz87
What did the top end rebuild actually consist of? The failed head gasket - was it 100% just a failed HG or was that just an assumption on an earlier issue?
Old Oct 26, 2020 | 01:12 PM
Ashley Howard
ST170
was a head gasket failure
it's had head skimmed , new valves springs and collets, stem valves
defo 100% water in cylinder 2 and 3
pa_sjo
Oct 13, 2016 08:07 AM
mk2tim
Ford Mondeo Including ST
Feb 22, 2006 05:04 PM
AndyRST
Ford Focus RS
Apr 7, 2005 01:24 PM
