Turbo blankets
Old Sep 28, 2020 | 08:47 AM
Mattus1000's Avatar
Mattus1000
Default Turbo blankets
Hi all,
What are your thoughts on turbo blankets? Just got an S112 from turbo technics (t34 with 0.55 housing), it's quite a lot bigger than my previous turbo and right by the engine now, wondering if a turbo blanket was a good idea?
Thanks
Matt
Old Sep 28, 2020 | 03:29 PM
cossie51's Avatar
cossie51
Originally Posted by Mattus1000
Hi all,
Thanks
Matt
If this is on a cossie then as long as you have the standard or aftermarket heat shield then you won't need a turbo blanket.
Heard mix stories on them, some say great others say they kill turbos due to holding to much heat. If you are going to buy one then spend the extra for a decent on as heard cheap ones don't last
Old Sep 28, 2020 | 04:41 PM
Mattus1000's Avatar
Mattus1000
Thanks for this mate...its on a cossie engine but not in an actual sierra or escort, no heat shield at all that I can see, do you have a link to one?
Yeah was thinking of the funk motorsport blanket which is Ł160 but I called turbo technics and they dont advise one...
Thanks for your help! Any chance you might also know where to get a cam belt cover too?
Old Dec 12, 2020 | 09:55 PM
1300gt's Avatar
1300gt
So in short, - if you have a water cooled ball bearing turbo . You are on gernal?...
blanket on hot side or not. With NO flat out top speed type runs etc ?
good or bad??
SGP
May 1, 2015 01:00 PM
Disabled Account
86
Nov 10, 2004 09:50 PM
Spiky
Sep 24, 2004 01:25 AM
