3door no fuel pump feed, spark, and eml light on
Old Aug 11, 2020 | 10:11 AM
richbogle's Avatar
richbogle
Default 3door no fuel pump feed, spark, and eml light on
Hi guys, my bros 3door packd in at weekend. Cut out at end of street. On a quick diagnosis there's no feed to fuel pump also the spark has gon. Management light also staying on. On a little investigating he found the inline 15A fuse jst next to ECU was blowing. Which we believe is the ECU fuse?? Replaced fuse and blowing straight away. Disconnected ECU, put fuse in and fuse OK. Soon as ecu connected the fuse goes. He done a continuity test between pin 20 on ECU and the body of ecu and and getting circuit. Think pin 20 is ecu feed?? And help atal guys much apreciated
Old Aug 12, 2020 | 10:21 AM
martysmartie's Avatar
martysmartie
You have a short circuit, it may be a fault with the ECU itself.
You won't have power at the pump, as the ECU drives the fuel pump relay. Likewise, ignition is controlled via ECU.
Do you have +12V at pin 20 with ignition on?
Martin
Old Aug 14, 2020 | 11:11 AM
richbogle's Avatar
richbogle
Martin
Hi mate sorry for the delay. I'm prity sure there is power at pin 20 when fuse is good anyway. Looking like a problem with ecu I think tbh. Cheers for reply
richbogle
Aug 15, 2020 09:34 PM
Yura
Oct 29, 2016 01:26 PM
muzzman1
Jun 10, 2013 08:15 AM
Matt Baxter
Mar 20, 2008 07:49 PM
dave cos4x4
14
Jun 5, 2006 09:34 AM
