R&D dogbox - Bellhousing
Hey,
I managed to pick up a 6 speed mt75 R&D dog-box.
Just wondering if anyone knows which bellhousing is required? I was hoping to use the T5 bell housing but unfortunately, the input shaft is ~10mm shorter than the T5 gearbox so an adapter plate may be out of the question.
the MT 75 gearbox doesn't have a seperate bellhousing its part of the casing, all the R&D MT75 gearboxes iv'e seen use the standard front casing
are you sure its an MT75 box?
Steve
Steve
https://www.ebay.co.uk/itm/MK2-Escor...MAAOSwQG9eHw-j
Okay, its based on a mt75 is probably a better way to describe, much the same as this gearbox on eBay (yet the 6 speed version), I've also seen lots of R&D mt75's use the integral bell housing
no worries, ill likely do what i can to retain the T5 bell housing as id prefer to have that as a easy swap backup. I think it may be possible but need the engine together to start measuring.
rich.edrsoc
Dec 17, 2008 04:32 PM
