Plenum breather?
Old Jul 31, 2020 | 01:20 PM
Leloby's Avatar
Leloby
5 Year Member
Default Plenum breather?
I'm trying to eliminate cutting out issues. New sensor kit being fitted. Found this breather valve on the plenum. Is it required or not - and where would the hose normally go? I see some being removed and blanked off.
Tried the compressor on it and air seems to get in but not out.
Cheers.
Old Aug 1, 2020 | 08:57 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
Part of original breather system. Nope you don't need it. Remove and blank. I believe hose would have gone to the flame trap...
Old Aug 1, 2020 | 01:24 PM
Leloby's Avatar
Leloby
5 Year Member
Thanks.
Old Aug 1, 2020 | 01:27 PM
tosh's Avatar
tosh
I think it’s a non return valve so should only work one way! Someone correct me if I’m wrong?
Old Aug 1, 2020 | 01:50 PM
christos's Avatar
christos
10 Year Member
Correct its a non return valve.
smokinjoe
Aug 28, 2011 01:09 PM
BRAMMER
Mar 7, 2011 10:10 PM
Ginge !
Oct 16, 2005 08:23 AM
